what is "Alternate switching"?
Discussion in 'General Electronics Chat' started by oki, Jan 3, 2014.
  1. oki
    Sep 13, 2013
    Hello everyone,
    I'm looking for the meaning of "alternate switching".
    What is it? and How it is used? I'm trying to tranlate the meaning of that into my language.
    "Alternate switching is mostly used in the lighting of staircases and long corridors."
    thanks.
  2. MrChips
    Oct 2, 2009
    12,624
    3,451
    My guess is that it is what is known as "3-way switch" in the electrical trade.
    It consists of two single-pole double-throw (SPDT) switches that are located at two ends of a long hallway or at the top and bottom of a staircase. With two switches a person can control the light fixture from either location.
    This is required by building code for stairways leading to a basement or cellar.
  3. mcgyvr
    Oct 15, 2009
    4,787
    973
  4. ScottWang
    Aug 23, 2012
    4,925
    777
  5. alfacliff
    Dec 13, 2013
    2,449
    428
    another use for "alternate switching" is pumps. two or more pumps are used in paralell,with a switch that selects one then the other. supposed to prevent pump failures. the switch also turns both on if needed. used for sewage lift pumps, and in reality, causes both to wear out at the same time.
