What is a good way to convert 110VAC to 12VDC or 24VDC
Discussion in 'General Electronics Chat' started by Sonoma_Dog, Sep 12, 2008.
  1. Sonoma_Dog
    Thread Starter Active Member
    Jul 24, 2008
    99
    I wanted to use the cheapest way to get/make a converter from 110VAC to 12VDC or 24VDC.
    my current requirement is at least 2A.
    I have notice that a 2A wall wart actually cost a lot, (around 15-40 USD). does anyone know a way to make/get one for cheaper?
    Thanks in advance
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
  3. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    If you have an old computer sitting around that has an ATX form-factor power supply in it, you can build an inexpensive bench supply out of it.
    I did that with an old 250W Compaq supply that I got for nothing, attached a plate with banana jacks, a power switch, and LEDs to show when it's powered up.
    Google "ATX bench supply" for lots of ideas.
  4. Sonoma_Dog
    Jul 24, 2008
    99
    Sweet, I actually have had build one of those before. But what i am looking for is something smaller that I can bring around.
    Thanks for the idea tho! really appreciate it! :)
  5. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    Well, check out Marlin P. Jones & Assoc.
    http://www.mpja.com/
    They have supplies of all kinds and all power ranges, and all price ranges.
    They even have a 12v, 2A supply for under $3.
    I don't order very frequently from them, but they always ship very quickly, and I've never been dissapointed.
  6. Sonoma_Dog
    Jul 24, 2008
    99
    Thank you, I will look into it !
    I also have some parts need to order.
    16MHz crystal oscillator
    5 volt regulator
    IRLZ14 logical MOSFET
    and some resistor.
    do you know any website that carry a lot of different component? I don't want to buy it from different websites because of the shipping cost. I checked digikey, they dont have IRLZ14 :/
  7. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    Here, get an IRLZ24 instead:
    http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail?name=IRLZ24NPBF-ND
    $1.68/each. They'll handle about twice the current as the IRLZ14 will, but that's OK.
    Why use a 2x4 when a 4x12 will work just fine? ;)
    Might want to get a few of the crystals. Try to avoid dropping them on a hard surface; they're pretty easy to break.
    As long as you're getting a 5v regulator, you might pick up a couple of LM317T's. Very versatile regulator.
    Careful with the MOSFET; they're very vulnerable to static electricity. One "zap" and they're toast.
  8. Sonoma_Dog
    Jul 24, 2008
    99
    excellent! going to order it tomorrow! Thank you!
