what is a good safe voltage for led light strip
Discussion in 'The Projects Forum' started by Arcamax, May 8, 2015.
  1. Arcamax
    May 5, 2015
    36
    i want to make a picture tracing light box/board and i was planning to use batteries to power it instead of a dc power adapter and i need to know what is a good battery that wont fry the strip.
  2. Dodgydave
    Jun 22, 2012
    5,150
    769
    you need to know what voltage and current the led strip needs, then choose a battery with the capacity that will last.
  3. Arcamax
    May 5, 2015
    36
  4. Dodgydave
    Jun 22, 2012
    5,150
    769
  5. Arcamax
    May 5, 2015
    36
    like i said i want make a light box/board to trace with, so maybe a couple(2) hours for sure if possible more.
  6. Dodgydave
    Jun 22, 2012
    5,150
    769
    looks like the leds take 1.2amp per strip, so 2.5amps total, for two hours is a 5ah battery, go for a 7ah 12v battery.
  7. Arcamax
    May 5, 2015
    36
  8. mcgyvr
    Oct 15, 2009
    4,789
    974
  9. Arcamax
    May 5, 2015
    36
    oh yeah sorry lol, didn't see the "m" on mAh.
    Anyway isn't there anything more portable i can get.
  10. Dodgydave
    Jun 22, 2012
    5,150
    769
    reduce the leds, or power consumption and then you can use a smaller battery.
  11. Arcamax
    May 5, 2015
    36
    oh yeah ok then, i was thinking of cutting sections and putting a little bit of wire in between each section of 3 led's possibly reducing some led's. About 1"-2" of wire
  12. Arcamax
    May 5, 2015
    36
    what about a power bank?
  13. OneFierceSon
    May 5, 2015
    8
    You could use something like this http://www.hobbyking.com/hobbyking/store/__9184__Turnigy_5000mAh_3S_20C_Lipo_Pack.html
    Lithium Polymer (Lipo) batteries will be the lightest you will find for your application and they come in all different shapes and sizes.They can be a little pricey though and they need a quality charger to go with them. You would need a 3s Lipo which just means it has 3 separate 3.7 volt batteries inside it. They are labeled 11.1 but when they are fully charged they are 12.6 volts, which
    is right around what your bulbs need. And remember you can always run multiple smaller batteries in a parallel configuration which will raise your amperage but your voltage will not be affected.
  14. Arcamax
    May 5, 2015
    36
    i'm still looking for something like this...
    but what if i took apart a dc adapter or other power supply, is there anything i can get
  15. Arcamax
    May 5, 2015
    36
  16. bertz
    Member
    Nov 11, 2013
    239
    31
    No and No! You need gobs of current and small batteries will not give you gobs of current for any length of time.
    Why cant you use an AC power supply? Is portability the issue?
  17. Arcamax
    May 5, 2015
    36
    Yeah i know i'll have to use an AC power supply, it's just that its nice when people have things that are portable... you know right.
    Is this good or too low Amps http://www.be-electronics.com/product_p/68-121a-1.htm
  18. Dodgydave
    Jun 22, 2012
    5,150
    769
  19. Arcamax
    May 5, 2015
    36
    urgh dont you just hate it when they have the wrong pictures. lol
