What is a current source?
panic mode
Joined Oct 10, 2011
2,750
in theory opamp has no voltage difference between inputs.
since one input is connected to ground, the other can be assumed to be at zero potential as well.
this means you can replace current source with fixed voltage source and adjustable resistor (potentiometer).
but 10uA is fairly small so assumptions on ideal opamp may not give you desired accuracy of the model.
current source is source that maintains named current regardless what is connected to it. if open circuit (infinite resistance) in theory it would produce infinite voltage. real current sources are more down to earth. basically they measure current and if it deviates from target, it adjusts potential difference so that ratio of voltage and load resistance is constant.
