What is a compression load cell?
Discussion in 'General Electronics Chat' started by Jhon Mick, Mar 24, 2015.
  1. Jhon Mick
    Mar 24, 2015
    Hi friends, I'm about to start my final year project that is based on load cells. In that the compression load cell will be playing an important role. So for that purpose could someone please provide me some information about the same. Thanks in advance.
  2. Reloadron
    Jan 15, 2015
    1,055
    275
    If you give this link a read note how the force is applied to several load cells in a downward motion compressing the cell. Thus the term "compression" is used. There are many designs of the basic load cell but the terms tension and compression are ever popular. The load cell you linked to is a compression cell, think about how the force is applied "compressing" the cell. If we were pulling outward on the cell it would be tension, pushing in is compression.
    Ron
  3. OBW0549
    Mar 2, 2015
    1,395
    941
    Load cells generally consist of one or more strain gauge elements (usually arranged as a Wheatstone bridge circuit) housed in a mechanical assembly that allows the strain gauge(s) to respond in a predictable and calibrated fashion to stresses (compressive, tensile or both) along a specific axis, while minimizing the response to stresses along other axes.
    What exactly is it that you want to know?
  4. forcemeasurement
    Oct 13, 2015
    Load/force---Element deformation---Strain gauge extended---Impedance change cause output change
    In short,compression load cell is a sensing element which converts load/force into analog output(normally in mV signal) which is proportional to applied force ,but only in compression
