Pretty much what the question says. Is it just a fancy name for any npn and pnp bjt?
Not at the TO-220 or TO-3 level. Too much heat to get rid of. You can still get them in TO-5 size or plastic DIP.It used to be that manufacturers would put the two devices on the same substrate. That way, thermal effects would occur equally on both transistors, thus minimizing the need for separate compensation circuits. I don't know if this is done any more.
There aren't many complementary pairs at that level.Not at the TO-220 or TO-3 level. Too much heat to get rid of. You can still get them in TO-5 size or plastic DIP.
