What is a 7/10" #14 Hairpin Inductor?
Discussion in 'Wireless & RF Design' started by doug08, Jun 5, 2011.
  1. doug08
    Jan 30, 2011
    153
    Is it just a #14 copper wire that is U-Turn bent tight to a length of .70"?
  2. #12
    Nov 30, 2010
    16,705
    7,358
    Does this do you any good?
  3. t_n_k
    Mar 6, 2009
    5,448
    783
    What's your specific application? Is it a hairpin match - say for a Yagi antenna ....?
  4. t_n_k
    Mar 6, 2009
    5,448
    783
  5. bertus
    Administrator
    Apr 5, 2008
    15,806
    2,390
    Are you refering to the 6 watt broadband amplifier?
    Here I have taken some picturs of an other amplifier with different syles of hairpin coils.
    The following one shows the thick wire hairpin as in your wanted schematic:
    The other two pictures shows the hairpin made out of strip material:
    The pictures are taken here at home.
    Bertus
    doug08 likes this.
  6. doug08
    Jan 30, 2011
    153
    I made that circuit, it works, but not really good. I only had a 2-3 watt fm transmitter to try and amplify. When I connect the transmitter to the RF amp with the known good tuned antenna, it only draws between 0 - 150 ma. This seems like nothing for 6 watts. The output also is 1 mhz off from the transmitter output frequency. I have a small transmitter that is between 100 and 300 mw....it does no amplification at all on those. Does my circuit look ok?
    Thanks.
    [​IMG][​IMG][​IMG][​IMG]
  7. bertus
    Administrator
    Apr 5, 2008
    15,806
    2,390
    You have to long wires for a RF circuit.
    There is a PCB drawin on the site of the schematic (although the coil numbering is wrong over there).
    http://www.21say.com/2sc1971-6-watt-broadband-fm-amp/
    Also the input power is to less, it needs 0,5 watts input for the 6 watts output.
    If the input power is to less the output power will drop very fast.
    Bertus
