what is 20 log (-10) =?
Discussion in 'Math' started by pot, Jan 1, 2016.
  1. pot
    Nov 9, 2015
    9
  2. djsfantasi
    Apr 11, 2010
    2,913
    881
    An error!
    Log is not defined for negative numbers.
  3. shteii01
    Feb 19, 2010
    3,518
    515
    Can you figure out a case where 10^x=-10?
  4. pot
    Nov 9, 2015
    9
    Must be briefed constant value even start drawing , use this equation ===> 20 Log(-10)
  5. shteii01
    Feb 19, 2010
    3,518
    515
    Absolute value of magnitude?
  6. GopherT
    Nov 23, 2012
    6,330
    4,080
  7. Wendy
    Mar 24, 2008
    20,772
    2,540
    Going on a limb here, but it strikes me as an imaginary number, similar to the square root of -1.
    atferrari likes this.
  8. shteii01
    Feb 19, 2010
    3,518
    515
    They are supposed to put frequency on the x-axis, and the absolute value of H(s) on the y-axis. Absolute value is Always positive. The correct formula is:
    <br />
Magnitude\quad in \quad dB=20*log_{10}(|H(s)|)<br />
    atferrari and pot like this.
  9. WBahn
    Mar 31, 2012
    18,093
    4,920
    Your question lacks context. As a pure math question there are a couple of answers:
    1) The normal logarithm function has the real numbers as both the domain and the range, hence the logarithm of a negative number is undefined since the base of normal logarithm functions are positive real numbers and there is no real exponent that you can apply to a positive real base and get a negative result.
    2) The logarithm function can be extended to the complex numbers, in which the log of every non-zero argument is defined, though it is, in general, a multi-valued function.
    But the look of the question implies that you are talking about voltage or current signals and converting them to decibels. In that case, you need to apply two functions, on for the magnitude and another for the phase. So you would have the magnitude as 20 log(10) and the phase as 180°.
    thumb2 likes this.
  10. dannyf
    Sep 13, 2015
    2,196
    417
    Express -10 in the exponential form.
    Alternatively, log(-10) = log(10*i^2) -> log (i). So express i in exponential form and you are done.
  11. WBahn
    Mar 31, 2012
    18,093
    4,920
    Sure. In fact, there are infinitely many values of x for which 10^x yields -10. Here's one of them:
    <br />
x \; = \; 1 + j \frac{\pi}{\ln(10)}<br />
    Let's check:
    <br />
10^x \; = \; 10^{\(1 + j \frac{\pi}{\ln(10)}\)}<br />
\;<br />
10^x \; = \; \( 10^1 \)\( 10^{\(j \frac{\pi}{\ln(10)}\)} \)<br />
    Since
    <br />
10 \; = \; e^{\ln(10)}<br />
    we have
    <br />
10^x \; = \; \( 10^1 \)\( {\(e^{\ln(10)}\)}^{\(j \frac{\pi}{\ln(10)}\)} \)<br />
\;<br />
10^x \; = \; 10e^{\(j \frac{\pi \ln(10)}{\ln(10)}\)}<br />
\;<br />
10^x \; = \; 10e^{j \pi}<br />
\;<br />
10^x \; = \; 10\(-1\)<br />
\;<br />
10^x \; = \; -10<br />
    thumb2 and Papabravo like this.
