What is 1.5V, 9V or 12V really means?
Discussion in 'General Electronics Chat' started by dtvonly, May 13, 2015.
  1. dtvonly
    Dec 14, 2012
    43
    Hi. By definition, "...Volt is a potential energy difference between two points....."
    So what is 1.5V, 9V or 12V really means?
  2. Papabravo
    Feb 24, 2006
    10,340
    1,850
    It means that if you put a fixed value of resistance across it, then a proportional amount of current will flow. That current is proportional to a certain amount of charge for a fixed amount of time. That's what it all means. What were you expecting -- something deep and profound?
  3. WBahn
    Mar 31, 2012
    18,088
    4,917
    By definition, 1 V is a potential energy difference of one joule PER COULOMB of charge between two points.
    That answers your question.
    1.5V means that there is a potential energy difference of 1.5 joules per coulomb between the points where that potential difference is measured. Similar for 9V, 12V, or 480,000 V.
  4. Dodgydave
    Jun 22, 2012
    5,159
    772
    voltage is the measurement of electric force between two points of the same circuit, the bigger the force the bigger the voltage is displayed.
  5. wayneh
    Sep 9, 2010
    12,394
    3,246
    "Force" is a mechanical term and I don't think it's appropriate for describing voltage. "Potential" seems to be the preferred term.
  6. WBahn
    Mar 31, 2012
    18,088
    4,917
    Force is measured in newtons, not joules.
    The electric field is a measure of the electric force (per unit charge) at a point in space.
    The voltage is a measure of the work (per unit charge) done in moving between two points in space.
  7. Dodgydave
    Jun 22, 2012
    5,159
    772
    ErnieM likes this.
  8. Papabravo
    Feb 24, 2006
    10,340
    1,850
    Semantic hairsplitting. Check the fundamental units -- they never lie.
  9. WBahn
    Mar 31, 2012
    18,088
    4,917
    It's an inherited travesty due to the sloppiness of previous generations made at a time both when things weren't nearly as well understood and also when rigor and consistency weren't as valued. Using the term "force" in this context is deprecated and causes all kinds of confusion because you tell people that something is a "force" when it isn't and, not surprisingly, they think that it is a force, when it isn't. This is made all the worse since there very much IS an electric force, namely the force exerted on one charged particle by all other charged particles.
    nsaspook likes this.
  10. WBahn
    Mar 31, 2012
    18,088
    4,917
    The term "force" is perfectly applicable in the electromagnetic realm, but you are correct that it is not appropriate for describing voltage because voltage does not describe a force. The very notion of voltage and electric potential come directly from Coulomb's Law describing the force -- as in F=ma force -- between two charged particles.
    Calling volts a measure of electric force is like saying that height is a measure of gravitational force.
    AnalogKid likes this.
  11. Kermit2
    Feb 5, 2010
    3,852
    968
    the little agitators bait the hook and we all fight to bite it!
    what is a volt? works here.
    what is a pound? would work somewhere else
    what is a gold standard? would set off the experts at yet another forum.
    I honestly believe half of these rudimentary questions are just clever trolling, since any 3 year old these days knows how to google such things. Yet, I often find myself leaping to answer such simple queries too. Just the nature of our basic personalities. We joined to help others gain understanding and are betrayed by our altruistic tendencies.
    MikeML and KLillie like this.
  12. WBahn
    Mar 31, 2012
    18,088
    4,917
    Quite true. I don't know how much of it is trolling, since there seems to be no shortage of people that genuinely seem to not understand these concepts no matter how much Googling they do.
    KLillie likes this.
  13. ian field
    Distinguished Member
    Oct 27, 2012
    4,459
    792
    Some context would make that easier to answer.
  14. studiot
    Nov 9, 2007
    5,005
    515
    These questions come round with every generation of students.
    There are two different quantities measured in volts.
    Electric Potential (which is not potential energy by the way).
    and Electric Potential Difference, (which is what I think you are talking about).
    So which one do you wish to ask about?
  15. WBahn
    Mar 31, 2012
    18,088
    4,917
    Voltage is always a potential difference. When we talk about the voltage AT a point being a certain voltage, there is ALWAYS a reference point and the voltage is always the potential difference between that point and the reference point. In physics, that reference point may well be at an infinite distance, just as the reference level for gravitational potential is often take to be at an infinite distance. This is for conservative electric fields; for non-conservative fields you also have to specify the path between the two points.
  16. studiot
    Nov 9, 2007
    5,005
    515
    I have to disagree with you there.
    Consider a thought experiment in a universe with only one single electric charge.
    There is an electric field emanating from that charge in all directions.
    What units do you measure that field in?
  17. wayneh
    Sep 9, 2010
    12,394
    3,246
    I think you'd call it neutral and there would be no field.
  18. studiot
    Nov 9, 2007
    5,005
    515
    Of course would be a field, that is electrostatics 101.
    I would think you will see a diagram of it in every EM textbook ever written
  19. WBahn
    Mar 31, 2012
    18,088
    4,917
    The electric field is measured in the same units as all electric fields, namely N/C. You can also express that in V/m. You cannot express the electric field in volts, since volts is not a measure of electric field.
    But let's leave the measurement of the electric field aside and take your claim that electric potential does not need to be relative to some reference. Okay, then if you say that the voltage at some distance from that charge is 100V, what does that mean? That's 100 joules/coulomb. What does that mean and why is it 100 joules/coulomb and not, say, 10 joules/coulomb or 1000 joules/coulomb. The answer is simple -- it is the net work that must be done on a unit test charge to bring it from rest at an infinite distance from your one single electric charge to rest at that point. And don't get hung up on the presence of a unit test charge in this universe that only has one single electric charge because the test charge does not have to physically exist, even in this imaginary universe, since it drops out of the integral and you are only integrating the electric field along that path.
  20. AnalogKid
    Aug 1, 2013
    4,705
    1,300
    If there is only one charged particle in the entire universe, there is no way to determine that it has a charge because there is nothing for that charge to interact with.
    ak
