what if i dont use the RFC!what will be the result!
studiot
Joined Nov 9, 2007
4,998
I can only recommend you do some serious studying of electronics before plunging into complicated circuitry.
You neither commented on nor appeared to understand explanations provided in earlier threads so I assume explanation is a waste of time here.
I will tell you that the RFCs are an necessary and essential part of the circuit which will not work at all without them.
Please take some advice and learn to walk before you run.
