what IC is this?
Discussion in 'General Electronics Chat' started by ljbp, Dec 28, 2011.
  1. ljbp
    Dec 28, 2011
  2. jimkeith
    Oct 26, 2011
    539
    99
    To me it looked like a transistor so, I googled: surface mount transistor identification
    This led me to: elektronik.googlecode.com/files/SMD_Catalog222.pdf
    Under "GG" there were 3 choices--since it appears to be a SOT89, I googled: BAW79C
    This led me to alldatasheet.com--in the middle of the page click on the link: BAW79C to view the pdf file
    Sure looks like the correct one--hopefully, that is all that is wrong with your board
    The "47K" could indicate a date or lot code ???
    ljbp likes this.
  3. Jotto
    Member
    Apr 1, 2011
    159
    17
    I didn't look up the part, but it could also use a 47k internal resistor.
  4. DerStrom8
    Feb 20, 2011
    2,428
    1,329
    A resistor with 4 pins? I think a transistor is more likely. Besides, SMD resistors use number codes to give the value. I have yet to find one that simply says 47K for a 47 kilohm resistor.
    Personally, I'd agree with Jim on this one.
  5. djsfantasi
    Apr 11, 2010
    2,905
    878
    If you do look up the part, jimkeith's process leads you to a description of a dual-Silicon Switching Diodes SMD part (For high-speed switching High breakdown voltage Common cathode). Not resistors; not transistors.
    DerStrom8 likes this.
  6. Lundwall_Paul
    Oct 18, 2011
    222
    19
    Try the attached data sheet. I believe HY57V641620 is the base number everything after that is package leads....
  7. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    Paul,
    The datasheet you attached is for an IC that has 54 pins. That's just 50 more pins than the package in question.
    For the SMD references I have, BAW79C is the only device that has the same package, and as has already been reported it's a dual diode 200v common cathode.
    But, my reference is a couple years old, and it's possible that a manufacturer used GG for another part. What causes me consternation is that the reference designator is Q903; the leading Q normally indicates a transistor of some variety; this reference designator should begin with "D". However, Q901 is the same part, so if one is careful, Q901 could be removed at the same time and tested.
  8. t06afre
    May 11, 2009
    5,939
    1,222
    My Turuta SMD-codes data book have these marked as GG and SOT-89 package
    GG 2SA1369-G Si-pnp AF-Drv, 30V, 1.5A, 500mW, B=400..800, 90MHz SOT-89
    GG BAW79C Si-diode Dual, Sw, 2x200V, 1A, <1000ns SOT-89
    GG RT9161A-45CX LVR-IC LDO, 4.5V±2%, 500mA SOT-89​
    GG– RT9161A-45PX LVR-IC LDO, 4.5V±2%, 500mA
    I found the 2SA1369 data sheet here http://www.datasheetcatalog.org/datasheets2/15/151654_1.pdf It looks kind of correct. Without saying it is your component 100%.
    ljbp and SgtWookie like this.
  9. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    Just going by the reference designator I'd say that the 2SA1369 is a better match.
    ljbp likes this.
  10. ljbp
    Dec 28, 2011
    And the winners of the Mistery IC Award are (drumroll please) t06afre and SgtWookie.
    At first I also thought it could be a BAW79C but after testing the IC it was clear that it wasn't a diode switch but a pnp.
    It's a 2SA1369 for sure. I already replaced it and everything is ok now.
    Many thanks to everyone for the amazing help.
    Lino
  11. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    Excellent! Thanks for letting us know it works.
  12. Lundwall_Paul
    Oct 18, 2011
    222
    19
    Thanks for the correction I was looking at the above it the one without the big red circle.
  13. thatoneguy
    Feb 19, 2009
    6,357
    718
    The codes are the one thing that really bug me about SMD.
    Many times, transistors are too small to write anything on, other than a microstamped letter, which is nearly useless.
    Or nothing at all, like the ones to the right of the transistor in question in the original image.
