I'm fabricating a massive Live-edge, wood slab milling machine. One of my motors that will move my cutting head is gear motor, 12v DC. The motor is stamped 1/4 hp and the max. amps (23). There is an in-line protector (10 amp). My remote control box has speed control & directional switch . . . . . .From control box to the motor is 30 ft.
. . . . .What gauge wire must I run ? There will be very little load on this motor, as it is just repositioning the head after each pass. It has a 60:1 gear ratio (41 rpm max.)
Any help would be greatly appreciated.
thanks, Dan
thanks, Dan
