I plan to add some LEDs to my car. On them it says input voltage = DC12v, and output current = 6A max. I plan to run these with a piggyback (expandable circuit) from my fuse board, so will a use a standard car fuse but not sure which one to get. The LEDs originally had a cigarette lighter plug attached to them, but i plan to un-solder this and re-solder it directly to the piggyback cable. In the original plug it had a F1AL250v fuse but i couldn't find the equivalent of this as a car fuse and not even sure if it would be the same. Thank you
