What function generator would you guys recommend for a cyamatics rig?
Discussion in 'The Projects Forum' started by Nitin Chetla, Feb 10, 2016.
  1. Nitin Chetla
    Feb 10, 2016
    5
    So, I have a high school project, and I am wondering what function generator you guys would recommend for a cyamatics rig. I already have around 200 watt amp which is connected to a subwoofer speaker. The function generator should send frequency hertz waves that go through the amplifier for amplification and then tones need to produced by the speaker.
  2. #12
    Nov 30, 2010
    16,658
    7,304
    An audio frequency signal generator.
  3. Nitin Chetla
    Feb 10, 2016
    5
    Do you have any cheap options? Like 100$ or less etc
  4. Dodgydave
    Jun 22, 2012
    5,134
    767
    Yes make one or buy one.
  5. shortbus
    Sep 30, 2009
    4,086
    1,664
  6. ScottWang
    Aug 23, 2012
    4,924
    777
    To buy a real function generator from 20Hz ~1Mhz or using the pc to generate the audio sound as these, and they are all free.
    Sinus23 likes this.
  7. bertus
    Administrator
    Apr 5, 2008
    15,796
    2,384
    Sinus23 likes this.
  8. Nitin Chetla
    Feb 10, 2016
    5
    Yes I can use a pc but would I need a pre amp connecting to an amp to amplify laptop signal?
  9. bertus
    Administrator
    Apr 5, 2008
    15,796
    2,384
    If you need a preamp depends on the sensitivity of the power amplifier.
    In audacity you can use the menu generate for several types of sounds to be generated.
    Bertus
  10. hp1729
    Nov 23, 2015
    2,071
    230
    Doesn't the audio amplifier kind of limit the frequencies to audio? Otherwise I would also suggest ultrasonic, at least.
  11. hp1729
    Nov 23, 2015
    2,071
    230
    20685 from Jameco Electronics. About $30.00. Built around an 8038 you can buy for less that $10.
  12. ScottWang
    Aug 23, 2012
    4,924
    777
    ultrasonic , 25Khz~60Khz?
  13. ScottWang
    Aug 23, 2012
    4,924
    777
    I bought a 8038 over 20 years, but I never use it ... :D
  14. hp1729
    Nov 23, 2015
    2,071
    230
    Dang, they have been around a long time, haven't they.
  15. ScottWang
    Aug 23, 2012
    4,924
    777
    I have to try it in these days to make sure are they alright or not, I just thought that the old components have a long life, except the lcd display, it is really sad because they are easy damaged.
  16. Nitin Chetla
    Feb 10, 2016
    5
    Ultrasonic is greeater then 20khz yeah
  17. Nitin Chetla
    Feb 10, 2016
    5
    Yes I looked at it, but I thought distortion might be a problem. The laptop wouldn't make an accurate enough signal, but I might be wrong. Any thoughts?
  18. shortbus
    Sep 30, 2009
    4,086
    1,664
    If your talking in the 'audio' range, I'd be willing to bet you wouldn't be able to measure the amount the tones would be off accuracy. Some people use them for musical instrument tuning.
