what frequency to use?
Discussion in 'Embedded Systems and Microcontrollers' started by oookey, Jul 31, 2012.
  1. oookey
    May 24, 2010
    62
    Hello, ;)
    I’m trying to use PIC16F628A to control 2 pcs of 74AHCT595 (Texas instrument) shift registers for matrix display.
    In the data sheets for both parts, max frequency for the MCU is 20Mhz, but the shift register min required 85Mhz! :eek:
    Would someone point me the right way of selecting the correct frequency? Thanks for your time.
  2. takao21203
    Distinguished Member
    Apr 28, 2012
    3,578
    463
    Hahaha. That's a funny idea they need at least 85 MHz.
    You can indeed apply pulses manually.
  3. ErnieM
    Apr 24, 2011
    7,440
    1,628
    Not 85 MHz minimum... 85 MHz MAXIMUM.
    One pulse per day is acceptable.
  4. kubeek
    Sep 20, 2005
    4,689
    806
    Page 7, fmax is at least 85MHz, this means it will work up to 85MHz or maybe higher, not that the minimum operating frequnecy is 85MHz.
