what does this mean (unsigned char *)&variable name
Discussion in 'Programmer's Corner' started by embpic, Apr 18, 2014.
  1. embpic
    May 29, 2013
    187
    hello master's
    what does this means (unsigned char *)&variable name.
  2. robvleugel
    Oct 3, 2013
    6
    &variable name is the memory address of the variable name, which you can store in a pointer. The parenthesis ( and ) are used to explicitly cast the pointer to a type of unsigned char pointer, in other words the resulting pointer is a pointer pointing to the size of an unsigned char on the memory address of variable name.
  3. ErnieM
    Apr 24, 2011
    7,436
    1,626
    To continue...
    A char type is typically 8 bits wide and the smallest memory element accessible. Even wider word processors (16, 32 or 64 bit) will gladly "pretend" to operate on individual byte size quantities.
    So "&anything" gives you the address of anything.
    Casting (converting the type) to a "char *" (char pointer) means "give me a pointer to the very first byte of whatever you are pointing to."
  4. embpic
    May 29, 2013
    187
    sorry for late reply.
    Code ( (Unknown Language)):
    1.
    2. address_variable = (unsigned char *)&variable_name
    if variable_name is int/unsigned int then what value will be in address_variable ??
    what should be data type of address_variable ???
  5. ErnieM
    Apr 24, 2011
    7,436
    1,626
    Irregardless of the declared type of variable_name, address_variable will point to the very first memory location of variable_name.
    The data type of variable_name is pointer to character.
    The type a pointer references is important when you increment or decrement the pointer. Those operations will be correct to point to the next element (they often skip more then 1 memory location).
