What does this do? SPNO
Discussion in 'The Projects Forum' started by rokz_2005, Jun 7, 2011.
  1. rokz_2005
    May 14, 2011
    68
    What does the below do.
    Is this also an SPCO.
    I am a little bit confused I would google it first but I was unable to find much info
    All I want to know is can I use this to switch between 2 power sources?
    DIL Reed Relay SPNO 12V Coil
    Note: Image is representative of range
    A good quality Single Pole, Normally Open reed relay that offers fast and quiet operation. Housed in a Dual in-Line package.
    Specification
    * Coil Voltage: 12Vdc
    * Coil Power: 144mW
    * Switching Current: 0.5A
    * Switching Voltage: 100Vdc
    * Operate Time: 1ms
    * Release Time: 0.5ms
    * Length: 19.9mm
    * Width: 7.62mm
    * Height: 5.5mm
    Title supposed to say 'What' sorry
  2. hgmjr
    Jan 28, 2005
    9,030
    214
    I would guess that SPNO would stand for Single Pole Normally Open. I don't have an explanation of SPCO.
    hgmjr
  3. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    I think a type C relay is double throw. You can tell with a meter and a voltage source.
  4. rokz_2005
    May 14, 2011
    68
    Sorry thats supposed to say SPNC not SPCO
    Is SPNO and SPNC same thing?
  5. Markd77
    Sep 7, 2009
    2,803
    594
  6. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    There is a datasheet available for download from this page:
    http://www.datasheetcatalog.com/datasheets_pdf/E/D/R/2/EDR201A1200Z.shtml
    The contacts are 1 form A.
    From the Wiki article:
  7. atferrari
    Jan 6, 2004
    2,667
    784
    NO normally open
    NC normally closed
    For every acronym, in any language, I run across, I type "XXX acronym" in the Google's text box .
    Up to now, I always got a result. Helpful.
