What does this circuit do?
Discussion in 'Homework Help' started by nightfury, Aug 29, 2010.
Thread Status:
Not open for further replies.
  1. nightfury
    Aug 29, 2010
    So, The Question is as follows:
    Your task is to analyse the logic circuit shown in Figure 2. The inputs to the circuit are C0, A0, B0, A1, B1, A2 and B2. The outputs are S0, S1, S2 and C3. The internal structure of the logic block in the middle of Figure 2 is shown in Figure 3.
    The circuit has seven inputs so while you might like to try a few different input com- binations to get a feel for the circuit, I suggest that you do not attempt to construct a full truth table. Rather, you should derive expressions for the outputs and see if you can make sense of the resulting expressions to determine what this logic circuit does.
  2. nightfury
    Aug 29, 2010
    Judging first of all from the nature of the level of our studies and by looking at the circuit itself, I have a hunch that it might be, arithmetic ( i.e Division, multiplication, subtraction, addition in that probable order ) of 3, 3-bit binary numbers.
    I made a rough truth table, but it didn't make much sense to me, so I think i might it made it wrong. I am currently working on it, but I am a bit short of time and hence decided to seek help as none of my friends could come up with ideas.
    I will work for a bit and keep checking for your replies.
    For further information, please post a reply,
    Anything will help, anything.
    Tell me if i`m in the right direction, or if possible, the answer.
    I will only check back if I cannot solve it myself, but I am short on time so please post your replies.
  3. nightfury
    Aug 29, 2010
    Ok a little bit of an update.
    Is it a 3-bit Carry lookahead adder? lol.
    I think I might have figured it out
  4. retched
    Dec 5, 2009
    5,201
    313
    Why yes it is.
  5. Wendy
    Mar 24, 2008
    20,772
    2,540
    Dat's what I'm seeing.
  6. nightfury
    Aug 29, 2010
    Ah...thanks guys.
  7. retched
    Dec 5, 2009
    5,201
    313
    You solved you own problem from 9:51am to 10:12am.
    You figured it out rather quickly. You seem to be a quick learner.
    You may be interested in reading our eBook.
    It is only $3,400 (FREE shipping and NO TAX!)
    But WAIT! THERES MORE!--- Because you are in our selected geographical region to receive educational aid, we will give you $3,400 off! (This special pricing is only available IN the Milky Way)
    To get to the ebook, there are links at the top of every page, or you can check out the Table of Contents HERE.
  8. gsanjaya
    Jan 18, 2016
    hi, do u have the full solutions of this question? thanks
  9. WBahn
    Mar 31, 2012
    18,087
    4,917
Thread Status:
