Since the associated components of the "driver" to the gate of the IGBT may be discrete components that form an essentially charged pump supply, perhaps the designers were simplifying the schematic using the "stuff goes here" drawing method. That said, perhaps when the diagram was published, mosfet/igbt pre-drivers were not readily available ? who knows ... In my old circuit, U$1 and the R2 formed the gate driver sub-ciruit. Trigger Pulse IN (TPIPD_IN) was a standard 3V logic high/low. TPIPD_OUT was the critical output, it had to work, and be managed carefully (once the IXDN604 was brought TPIPD_IN low, energy was still stored in the chip for at least one or two additional triggers. I need to figure out how to bleed that once I redo this circuit in a few months.To clarify: I haven't seen this iteration before, and I'd like to understand it better. I've researched the different IGBT symbols that are commonly used, and noted their differences, but this appears to be unique.
by Duane Benson
by Jake Hertz
by Aaron Carman
by Jake Hertz
