what does Register tranfer level mean ?
Discussion in 'General Electronics Chat' started by revooridinesh, Jul 6, 2011.
  1. revooridinesh
    Jul 6, 2011
    plz explain in simple words in simple language difference between register transfer level behavioural level and gate level explain the RTL part more clearly
    Thank you
  2. guitarguy12387
    Apr 10, 2008
    For RTL level design, you have a datapath and a controller which are designed separately. It is fairly high level design. You tend to use functional blocks in your algorithm development and an FSM to source the control signals.
    Gate level is just that... designing with discrete logic gates! It doesn't get lower level than this for logic design, unless you want to start working with transistors.
