what does n.c means in this IC?
Discussion in 'General Electronics Chat' started by cczone, Dec 19, 2008.
  1. cczone
    Dec 17, 2008
    23
    Hi, might need to ask what is the meaning of n.c here? Not connected?
    Pin 7 here is basically write protect input.
  2. garry.owens
    Member
    Dec 17, 2008
    17
    nc on a chip usually means not connected
  3. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    Yes, no connection.
    That particular IC has a pull-down on the write protect pin to enable writes by default.
    If you want to disable writes, pull that pin high.
    http://www.pira.cz/pdf/24xx256.pdf
  4. cczone
    Dec 17, 2008
    23
    Thanks guys. Got it :)
  5. KL7AJ
    Nov 4, 2008
    2,047
    295
    It means the chip is made in North Carolina. :)
  6. Audioguru
    Dec 20, 2007
    9,411
    896
    The only chips made in North Carolina are the potato kind.:p
  7. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    For an IC pin, NC will be "no connection". For a switch or relay contact, NC means "normally closed".
