What does "LPS" on a power supply mean?
Discussion in 'General Electronics Chat' started by wayneh, Dec 10, 2015.
  1. wayneh
    Thread Starter Expert
    Sep 9, 2010
    12,395
    3,246
    I see that the acronym stands for "limited power supply", and I've read this but I still don't quite get it. Why would you put that on the label of an AC/DC adapter? Is it just a statement of compliance with a standard? Are there examples of AC adapters that are not LPS worthy?
  2. Dr.killjoy
    Apr 28, 2013
    1,210
    158
    It's pretty much stating that a power supply can provide say 30v and 3 amp and no more .. Somethings can be ran above their specifications ,but with LPS the circuit has protection against it in order to be a safer product in case of error or failure..
    Hope it helps
  3. MaxHeadRoom
    Jul 18, 2013
    10,860
    2,525
    Stands for Linear Power supply.;)
    As opposed to SMPS.
    Max.
  4. wayneh
    Sep 9, 2010
    12,395
    3,246
    Ooh, Max, I don't think that's true. Another source.
    Here's an example. Note the "LPS" next to the pinout:
    AnalogKid likes this.
  5. nerdegutta
    Dec 15, 2009
    2,569
    806
    Even in Swedish: "Endast för kontormaskin".
  6. MaxHeadRoom
    Jul 18, 2013
    10,860
    2,525
  7. mcgyvr
    Oct 15, 2009
    4,791
    976
    LPS = Limited Power Source
    Basically 20VDC or less output and meeting the other requirements by the use of PTC fuses,etc...
    Making it "consumer" safe to access without a tool or trained individual.
    Tests and marking requirements come from the standard bodies..
    UL60950, UL 2054,etc.. (and their IEC/EN,etc.. equivalents)
  8. MaxHeadRoom
    Jul 18, 2013
    10,860
    2,525
    I guess we will have to come up with another one for a Linear Supply:rolleyes:
    Max.
  9. mcgyvr
    Oct 15, 2009
    4,791
    976
    BA..Boat Anchors
    The 20V "consumer safety" requirement is also why many laptop power supplies output 19VDC..
  10. AnalogKid
    Distinguished Member
    Aug 1, 2013
    4,705
    1,300
  11. MaxHeadRoom
    Jul 18, 2013
    10,860
    2,525
    That's a laugh, there is no way I would use anything but a linear supply on a servo or stepper system for my installations.
    Max.
    shortbus and Hypatia's Protege like this.
  12. Techno Tronix
    Member
    Jan 10, 2015
    140
    10
    If a piece of electrical or electronic equipment supplying DC power to external devices is to be installed by a third party, such as an electrician, the risk of wiring fires & electrical shock needs to be minimized. By using a Limited Power Source, the system wiring can also be reduced, saving cost.
  13. Hypatia's Protege
    Mar 1, 2015
    2,850
    1,317
    Perhaps in the manner of a limited disinfectant? -- IOW specified only to extent tested...?
    MaxHeadRoom likes this.
  14. Dodgydave
    Jun 22, 2012
    5,159
    772
  15. Hypatia's Protege
    Mar 1, 2015
    2,850
    1,317
  16. wayneh
    Sep 9, 2010
    12,395
    3,246
    There's a button for that!
  17. AnalogKid
    Aug 1, 2013
    4,705
    1,300
    Not big enough. There needs to be a triple-like option.
