What does lower current frequency of an npn transistor depends on?
Discussion in 'General Electronics Chat' started by viji sathish singh, May 19, 2016.
  1. viji sathish singh
    May 19, 2016
    lower current frequency of npn transistor depends on what.
    is it System Voltage, I/P impedence or O/P impedence.
    Some one please clarify
  2. wayneh
    Sep 9, 2010
    12,371
    3,224
    Can you restate your question, or perhaps supply a schematic of what you are asking about? "Lower current frequency" is not a property of a transistor.
  3. hp1729
    Nov 23, 2015
    2,084
    232
    Is that frequency response of a low level signal? Frequency-Gain characteristic? Then is his answer yes, yes, yes and the capacitances of the transistor?
  4. crutschow
    Mar 14, 2008
    13,473
    3,361
    Bipolar transistors have inherent gain-bandwidth that depends upon the internal transistor design. This cannot be changed for a particular transistor.
    In a circuit, input and output impedances, as well as operating current also affect the frequency response.
