What does it mean to calibrate an antenna
Discussion in 'Homework Help' started by Ali Alkhudri, Nov 26, 2015.
  1. Ali Alkhudri
    Nov 3, 2015
    19
    Hi
    I found this citat in my book Williams, "EMC for product designers" : The antenna must be calibrated in terms of volts output into 50 ohm for a given field strength at each frequency ...
    what does this mean ?
    thanks
  2. Papabravo
    Feb 24, 2006
    10,340
    1,850
    For most applications of an antenna, calibration is not required. When used as part of a measurement system you need to know how Electric Field Strength and Magnetic Field Strength induce voltages and currents in an antenna and whatever load is connected to the antenna.
  3. ian field
    Distinguished Member
    Oct 27, 2012
    4,447
    791
    Just throwing a wild guess - it may have something to do with SWR.
  4. Papabravo
    Feb 24, 2006
    10,340
    1,850
    SWR is irrelevant for a receiving antenna where you are interested in converting volts/meter into volts into a 50Ω load.
  5. JoeJester
    Apr 26, 2005
    3,402
    1,221
    You need a calibrated system, antenna included, when making field strength measurements.
    Amps per meter and volts per meter are typically the requisite measurements concerning SAR.
  6. ian field
    Oct 27, 2012
    4,447
    791
    SWR is relevant on receive if you're after very weak signals.
    On transmit; bad SWR can blow your PA transistor - its effects on receive are less dramatic, but it still has a bearing on how much signal gets down the feed line.
