What does give HNC in Instrumentation from UK university?
Discussion in 'Off-Topic' started by SergePSN, Mar 30, 2011.
  1. SergePSN
    Feb 23, 2011
    Dear Forum inhabitants
    Who can suggest me info about it
    What it gets you If you get this degree, career, ladder rises, promotions...etc.
    Is this the way to become an engineer? Is it worth?:rolleyes:
  2. DumboFixer
    Feb 10, 2009
    219
    34
    An HNC (Higher National Certificate) is not a Degree (it's less than a Degree with an HND (Higher National Diploma) above the HNC and below the Degree).
    It will put you on the career ladder (unfortunately not from the bottom or school leaver level) and will help but not as much as a Degree (BSc) will.
  3. Dave
    Retired Moderator
    Nov 17, 2003
    6,960
    145
    If you couple it with formal vocational training it is very good. As previously said, it isn't the level of a degree and may consider using your HNC as a stepping stone to going on an doing a degree. It will at least give you that option.
    Dave
