in this application note:
http://sci-toys.com/scitoys/scitoys/computers/thermometer/how_the_LM34_works.pdf
page 5, section "Fahrenheit temperature sensors", it says:
"The sensor can be used with a single supply over the full −50 ̊F to +300 ̊F temperature range, as seen in Figure 10, simply by adding a resistor from the output pin to ground, connecting two diodes in series between the GND pin and the circuit ground, and taking a differential reading. This allows the LM34 to sink the necessary current required for negative temperatures."
What does "differential reading" mean in this context?
