This is where I get confused. since oscillator is running in 20MHz frequency, then what does this 0Hz implies?Direct Current, i.e. 0Hz.
"0 Hz" means that the MCU is specified down to DC for its clock. Now, a DC "clock" might not be useful, but you might want to use an external clock at a much lower frequency than, say 32 kHz. Maybe for some applications something as slow as 10 to 100 Hz might have a use. You can also clock through a program at a very slow pace.
John
It implies that the clock signal can be stopped without loosing operations. Older processors had a minimum clock frequency. I have never tried it but you might be able to step a processor through operations at a manual clock speed if it says that it goes own to DC.Can anyone please tell what does DC in oscillator specification of a microcontroller means ?
by Jake Hertz
by Duane Benson
by Aaron Carman
