What does Bandwidth mean in Satellite
Discussion in 'Wireless & RF Design' started by RRITESH KAKKAR, Nov 21, 2015.
  1. RRITESH KAKKAR
    Thread Starter Senior Member
    Jun 29, 2010
    2,831
    89
    What does Bandwidth mean. In Satellite Communication?
  2. BR-549
    Sep 22, 2013
    2,184
    421
    It is the width of a band. Google is a great dictionary.
    RRITESH KAKKAR likes this.
  3. nsaspook
    Aug 27, 2009
    3,019
    2,384
    Nice launch.
    There is the bandwidth of raw RF frequency band size for each down-link transponder. The channel allocation for a system might be say 20MHz but H/V antenna polarization is used to separate the signal overlap with 40MHz between same polarity. The digital signal S/R (for TV, etc...) throughput speed is another measure that might be a signal 'bandwidth' here.
    C and Ku band transponders at the location GSAT-15 is headed to.
    http://www.lyngsat.com/Insat-3A-4B.html
  4. RRITESH KAKKAR
    Jun 29, 2010
    2,831
    89
    I have seen tower and satellite transmitter and receiver.
    how they send signal, in micro controller we just use gates with logic. what about transmitters?
  5. fiberstorejames
    Aug 5, 2014
    18
  6. alfacliff
    Dec 13, 2013
    2,449
    428
    there are differfent types of transpoonders, the "bent pipe" is the simplest, just a reciever front end, if, and mixer to transmit frequency folowed by power amplifier. the "bandwidth" would be determined by the filters in the IF stage.for satelite transponders, it would be uneconomical to have the signal detected and decoded, then to have that modulate the transmitter.
