Here is another question. I noticed that many of the LEDs with a high mcd rating have a narrow viewing angle. So I wonder if they are really brighter of if the same amount of light may simply be concentrated in a smaller area? Here are the specs for a couple LEDs I'm considering for the LED afterburner ring:
1) 5mm straw hat LED, 10,000 mcd, Vf 3.0-3.4v, Viewing angle 120 degrees, 20 mA
2) 5mm LED, 25,000 mcd, Vf 1.9-2.3v, Viewing angle 25 degrees, 20 ma
Which would be better? I'm guessing #1 may be better despite the lower MCD rating because of the wide angle. The airplane will seldom be seen level straight from behind so unless the LEDs have a wide angle, maybe they will not show up that well in the daylight?
