what does Arduino Shield mean?
Discussion in 'Embedded Systems and Microcontrollers' started by steven334, Jan 9, 2012.
  1. steven334
    Aug 9, 2011
    37
    In Arduino Speak what does Arduino Shield mean? And what does breakout board mean?
    thanks
  2. t06afre
    May 11, 2009
    5,939
    1,222
    Shields are boards that can be plugged on top of the Arduino PCB. Breakout boards. Many components may be hard to connect to. Like many SMD chips. By using a breakout board. You can distribute the connections so they may be more easy to connect without being an expert solder. As an example this one. The board contain a pre mounted PIC chip. And hobbyist friendly solder connections
    http://www.microchipdirect.com/productsearch.aspx?Keywords=MA330013
  3. hgmjr
    Jan 28, 2005
    9,030
    214
    Arduino's original designer simply decided to refer to the boards that plug onto the main microcontroller board (Arduino Uno or Arduino Mega256) as shields.
    hgmjr
