What do you guys use as flash?
Discussion in 'The Projects Forum' started by rougie, Feb 25, 2010.
  1. rougie
    Thread Starter Active Member
    Dec 11, 2006
    410
    It has been a while I was successfully able to get the M29W160EB flash to work on my target board. If you look over the spec of this flash at:
    http://www.numonyx.com/Documents/Datasheets/M29W160E.pdf
    you can see that their are alot of details to worry about when making a driver for this chip. Yes, I unfortunately did my own driver instead of just using the drivers available on the Numonyx site.
    I was wondering what flash chips are you guys using and if they are easier to use then the one I am using. The reason I ask this is because, I will need a bigger flash chip, and I was wondering if someone can reccomend me an easier flash than the M29 familly.
    I looked at the bigger flashes on the Numonyx site like the M29DW256G but it seems to be just as complicated as the M29W160EB and I don't really know if the driver I made for the M29W160EB would work for the M29DW256G ??? I would need to do some extensive testing to know this!
    I welcome all feedback pointing to new and easier flash chips that are available on the market.
    Thanks in advance
    Rob
