What equation should be written between Node Vc and Vd the Short Circuit
ThanksVc and Vd are the same node as far your calculations go.
Note that the voltage across current sources is not zero, as your equation for Va assumes.
What Should be doneHi,
Do i see this:
Va/30=10
Va=300
That does not look right.
Hi,What Should be done
ThanksHi,
Well Nodal is based on the sum of ALL the currents into a node, not just the current from one branch.
For example if we have three resistors all having one terminal connected to a single node Vx and each having voltage v1,v2,v3 on their other terminals then the equation is:
(v1-Vx)/R1+(v2-Vx)/R2+(v3-Vx)/R3=0
so you see the sum of all three currents into the node is zero. We can not just do (v1-Vx)/R1=0 for example because that is only one of the currents into the node.
by Jake Hertz
by Duane Benson
by Jake Hertz
