what could be the minimum frequency of digital signal ?
Discussion in 'General Electronics Chat' started by munna007, Jan 10, 2011.
  1. munna007
    Thread Starter Active Member
    Jul 23, 2008
    51
    hello frends.....this question is asked to me in interview.....i am unable to find its answer....can u please tell me ????
  2. Audioguru
    Dec 20, 2007
    9,411
    896
    The opposite of an infinite frequency.
    One cycle each zillion light-years.
  3. hgmjr
    Jan 28, 2005
    9,030
    214
    As audioguru has indicated there is no practical limit to the length of the period of a squarewave. Is there a particular low frequency in which you are interested?
    hgmjr
  4. Papabravo
    Feb 24, 2006
    10,340
    1,850
    The practical answer is zero or DC. I don't see why this should be such a challenging question.
  5. jpanhalt
    Jan 18, 2008
    5,699
    909
    Maybe the interviewer was interested in the minimum digital sampling frequency needed, i.e., Nyquist.
    John
  6. russ_hensel
    Distinguished Member
    Jan 11, 2009
    820
    47
    Actually the period cannot exceed the age of the universe. If you have a signal at 0 hz, you may have to wait a while, or a long while or a longer while to see if it really is 0.
  7. thatoneguy
    Feb 19, 2009
    6,357
    718
    If sampling, then at least twice the highest frequency you want resolution of.
    For standard gates, DC, in the "ideal sense", 0 Hz for ∞.
  8. Papabravo
    Feb 24, 2006
    10,340
    1,850
    The point is that any DC signal including GND fits the literal definition of "periodic" in the sense f(x) = f(x+2∏) for all x from -∞ to +∞. I don't have to wait for the end of the universe, DC is DC and constant by definition.
  9. tom66
    May 9, 2009
    2,613
    214
    Light years measure distance, not time.
  10. #12
    Nov 30, 2010
    16,665
    7,310
    Audioguru is allowed these due to his great age and wisdom.
  11. Audioguru
    Dec 20, 2007
    9,411
    896
    OK, I'll correct myself.
    The time it will take you to walk the distance a light beam travels in a zillion years.
  12. tom66
    May 9, 2009
    2,613
    214
    Make it infinity and you've got a deal.
  13. russ_hensel
    Jan 11, 2009
    820
    47
    Yes and for all frequencies. But you do not know it is DC if you do not wait, it may simply be a long period square wave.
  14. Papabravo
    Feb 24, 2006
    10,340
    1,850
    I agree if you are conducting an experiment. The original question asked for a minimum frequency. Zero frequency is one possible answer if you allow a constant value to be included in the set of periodic waveforms. The other possible answer is some infinitesimally small frequency ω that approaches zero from the right, call it 0+, and as has already been observed, you will have to wait a long tome to see it return to its original value.
  15. thatoneguy
    Feb 19, 2009
    6,357
    718
    Think about giving that answer in an interview though, especially if they actually were looking for the Nyquist limit.
    I've had some interviewees crash and burn by thinking every question had a hidden "trick answer".
  16. CDRIVE
    Jul 1, 2008
    2,223
    99
    I would have given the identical answer.
  17. munna007
    Jul 23, 2008
    51
    in digital singla processing by prokias its written that frequency of digital signal varies from -1/2 to +1/2 hz.is it write ????
  18. jpanhalt
    Jan 18, 2008
    5,699
    909
  19. Papabravo
    Feb 24, 2006
    10,340
    1,850
    Not quite. In the continuous domain there is no concept of negative frequency. In the digital domain there are two thing going on:
    1. A "band-limited signal" has a certain bandwidth. That is there is a minimum and maximum frequency. Signals are often represented by centering the band about the vertical axis. So negative frequency is that part of the band below the "center frequency"
    2. Frequencies in cycles per second(Hz.) or radians per second are normalized with respect to the sampling frequency givina a range of [0..1]*Fs or [-0.5..0.5]*Fs, where Fs is the sampling frequency. The sampling frequency needs to be at least twice the frequency of the highest frequency in the signal being sampled.
