what circuit is it?
Discussion in 'Homework Help' started by bug13, Aug 28, 2012.
  1. bug13
    Feb 13, 2012
    1,213
    38
    as seen in picture, what sort of circuit is it? does it have a name? what should I google for to find out more about it? and how do I do the calculation etc..
    this circuit is use to sense the voltage of a AC source, that all I know
  2. t_n_k
    Mar 6, 2009
    5,448
    783
    The intent is probably creating a DC offset AC signal. Looks very unsafe to me.
  3. bug13
    Feb 13, 2012
    1,213
    38
    How's that work?
  4. t_n_k
    Mar 6, 2009
    5,448
    783
    See the attachment - but don't try to build it as a real circuit. You could be electrocuted if something goes wrong or you make an error.
    bug13 likes this.
  5. Jony130
    Feb 17, 2009
    3,990
    1,115
    The large capacitor you can treat as a voltage source as long as R*C (capacitor time constant) >> 1/f_ac_signal.
    So in your digram capacitor is charge to
    Vc = Vdd * R4/(R3+R4). So simply replace capacitor with Vc voltage source.
    bug13 likes this.
  6. bug13
    Feb 13, 2012
    1,213
    38
    which resistor/s do I use to calculate the time constant?
  7. Jony130
    Feb 17, 2009
    3,990
    1,115
    Well I think that the time constant is equal to resistance seen from the capacitor terminal. t = R * C ---->R = R3||R4 + R1||R2
  8. bug13
    Feb 13, 2012
    1,213
    38
    ok, this confused me more, I simply don't understand why R3||R4 and R1||R2, if || here means parallel.
  9. Jony130
    Feb 17, 2009
    3,990
    1,115
    Simply you must find a equal resistance seeing from the capacitor terminal when the other remaining voltage source replace with a short-circuit.
