I am having trouble trying to figure out what parts to use for the adder, adder/subtractor, and multiplier in the following portion of this pspice circuit:
I have already built and simulated it in Pspice. However, I am also required to build a physical circuit on a breadboard. I have never used to following three components in a physical circuit: (Note: Ignore the two parallel lines that look like a capacitor.)
Are there certain IC's I am supposed to use for them (maybe like a digital logic adder?). Also, the figure shown above is only a portion of the whole circuit. The entire circuit has many voltage sources, each having a different value. I only have access to one power supply. Can I use 9v batteries for each source? If so, how would I manipulate the voltage?(voltage divider?). Lastly, can I use a 9v batter for a current source (As shown in the figure above as I1 and I2)?
