what chip should i use to have a lowpass filter
Discussion in 'General Electronics Chat' started by pinoyballer, Dec 1, 2007.
  1. pinoyballer
    Oct 31, 2007
    11
    FIlter out any signal higher than 100k Hz
  2. eeboy
    Sep 27, 2007
    90
    What does the output feed?
    If you are feeding the input of an ADC (or another high impedance load) why not just use a RC filter configured as a low pass?
  3. nanovate
    Distinguished Member
    May 7, 2007
    665
  4. pinoyballer
    Oct 31, 2007
    11
    im trying to feed it to a ADC converter. is there a chip that i can use?
  5. eeboy
    Sep 27, 2007
    90
    No need for a chip in this situation.
    A 15.8k Ohm resistor in series with a 100pF cap shunted to ground will give you a cutoff frequency of 100kHz.
  6. pinoyballer
    Oct 31, 2007
    11
    what order filter is this?
  7. pinoyballer
    Oct 31, 2007
    11
    what kind of filter is this? and what order?
  8. eeboy
    Sep 27, 2007
    90
    It's a first order low pass filter.
  9. MDK
    Member
    Feb 1, 2008
    22
    You dont need a chip all you need is a resistor and a capacitor.
    This circuit will give ayou a cut off point of about 1K and a drop of about 3db per octave.
  10. Ron H
    Apr 14, 2005
    7,050
    657
    That has a 3dB cutoff frequency of 284Hz, and drops at 6dB per octave.:rolleyes:
    Pinoyballer wants a 100kHz cutoff frequency, we think.
