Hi All,
I have been working on this 9-band filter found elsewhere on the interweb. I have the buffer and the first three filters built. It works pretty well, but I'm using electrolytic caps. Looking at the schematic the capacitors used appear to be tantalum. The part used in schematic is: C-EUC0805K
Is this correct? Are all caps supposed to be tantalum?
I understand that it sounds like I already know the answer is yes - tantalum. The problem is that I can not find any through hole 10nF tantalum caps. I can find them in surface mount. Is there such a thing as through hole 10nF Tantalum capacitors?
Thank You,
John
Thank You,
John
