What can I light up with 5 mW?
Discussion in 'The Projects Forum' started by fluttermanman, Mar 30, 2010.
  1. fluttermanman
    Mar 30, 2010
    10
    I have 5 mW of power available from a wind energy harvester. What can I light up to demonstrate that my harvester works? Most LEDs seem to have forward voltages in the 1-10 V range, and I'm nowhere close.
    A link to a potential product for me would be extremely helpful.
    Thank you
  2. Audioguru
    Dec 20, 2007
    9,411
    896
    5mW is a very low power. We don't know if the voltage is a few volts to dimly light an LED.
  3. R!f@@
    Apr 2, 2009
    8,785
    771
    nano motor is an idea
  4. fluttermanman
    Mar 30, 2010
    10
    Let me modify my query:
    What is the least amount of power that I will need in order to initiate a physical process (e.g. light up, cause to rotate, etc) anything visible to the naked eye? I have a device that outputs 5 mW, and I have no access to external power. If I'm going to go up onto a stage to show people that this device works, what can I use to show them that there is indeed some power there?
    Is it possible to store energy from such a low-power output device?
  5. KMoffett
    Dec 19, 2007
    2,584
    234
    What's the voltage output?
    Ken
  6. Audioguru
    Dec 20, 2007
    9,411
    896
    5mW into a 1.8V red LED lights it with 2.8mA so it will be clearly visible.
    You keep talking about 5mW but we must know what is its voltage when it is loaded with 2.8mA.
  7. fluttermanman
    Mar 30, 2010
    10
    RMS Voltage for signal = 200 mV
    Inductive coil resistance = 8 ohms
    A red LED should do the trick?
  8. Audioguru
    Dec 20, 2007
    9,411
    896
    A red LED needs 1.8V to 2.2V. It won't do anything with only 0.2V.
    I don't know anything that will show something when it is fed only 0.2V.
    You forgot to say the frequency. A transformer can increase the voltage to anything you want and light an LED.
  9. retched
    Dec 5, 2009
    5,201
    313
    Are your diodes in backwards?
    Even with a little model motor and a 3 inch plastic prop, im getting greater power.. Is this a micro/nano harvester?
    You could dump the POWER (big letters) into a capacitor for a few months and get some useable juice. (Maybe not that long)
  10. KMoffett
    Dec 19, 2007
    2,584
    234
    An analog meter. :)
    Ken
  11. Audioguru
    Dec 20, 2007
    9,411
    896
    When an analog meter is on a stage then the audience will not see its tiny needle move.
  12. KMoffett
    Dec 19, 2007
    2,584
    234
    A video camera pointed at the meter and a monitor pointed at audience.
    Ken
  13. fluttermanman
    Mar 30, 2010
    10
    Yes, it is a microharvester. It uses membrane oscillations to accelerate the magnets; wind induces the vibrations in the membrane.
    Peak frequencies in my frequency analysis are anywhere from 5-50 Hz. It's a very complex motion.
    I'll see what voltages I can get out with a smaller wire gauge (48) and a bigger coil spool. Also, I'm using NeFeB magnets. Know of any stronger, relatively cheap permanent magnets?
    I obviously can't afford significant losses. What kind of efficiencies could I expect from a well-designed transformer?
    Thank you all for your help.
    P.S. For some background, I'm working on a substantial modification of this sytem: http://www.popularmechanics.com/technology/industry/4224763.html. The "power conditioning unit" mentioned at 0:59 is what's giving me trouble.
  14. fluttermanman
    Mar 30, 2010
    10
    In case anybody's working on a similar project, the solution to this problem was embarassingly simple: increase the number of turns per coil by reducing wire size (increasing wire gauge). With a 3,000 turn inductive coil, I am now able to light up several LEDs in parallel.
    Thanks for your help!
  15. fluttermanman
    Mar 30, 2010
    10
  16. KMoffett
    Dec 19, 2007
    2,584
    234
    Good work. Congratulations!
    Ken
