What can I build
Discussion in 'General Electronics Chat' started by jchal3, Mar 14, 2010.
  1. jchal3
    Dec 13, 2009
    78
    So I was going through my garage today and looking to get rid of some junk that's in there. I found 4 d-10-100 satellite receivers. They have everything with them. The power chords, cards, and remotes.
    I wanted to make sure they weren't good for anything before I threw them away. Any of ideas on what a guys could make out of these?
  2. hwy101
    May 23, 2009
    91
    28
    They're good for parts
    voltage regulators, diodes, capacitors, etc...
  3. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    They might have a high frequency divider in the RF section that would make a great front end for a frequency counter. Read the part numbers from the ICs and search for the datasheets.
    There is probably a large toroid with the mains power wires wound through it several times. You can use these for lots of things such as low frequency inductors and transformers for switching power supplies. You may also find a number of CMOS digital ICs, switching transistors, and a variety of capacitors.
