I managed to to destroy two GFCI outlets today by shorting neutral to ground when run off a schumacher 750 watt inverter. They reset a few times but then nothing, they can not be reset. I was deliberately doing that to see if they would trip off, and they did not trip. The inverter did overload a few times before finally blowing a mosfet, which I replaced and it works again.
The GFCI did trip off with the test button, but a direct short killed them both. Both GFCI mechanically look fine.
I took apart the Leviton and it has a small PC board. About the only thing I could replace is a transistor.
Do those devices have an onboard fuse soldered in?
Over the years I have had maybe 10 of these just fail for no good reason, one day they worked, another they did not. So I would like to know are they mostly junk and designed to trip off break and not work well after some age is on them?
