What boards to solder on for high current circuits?
x1222
Joined Oct 22, 2011
31
I'm working on voltage regulator circuits to control the voltage for 4-5 servos and the total stall torques will be up to around 8 A. From googling, typical PCB prototype boards seem to only be rated for around a few amps. Are there specific boards I should look for to handle the higher currents?
R!f@@
Joined Apr 2, 2009
9,918
No specific boards but the copper trace width and copper oz is taken into account when dealing with high current tracks.
Another way is to cover the whole trace with solder. This will increase the current handling in thin traces.
tracecom
Joined Apr 16, 2010
3,944
You might consider using flywires for the high current portions of your circuit.
mcgyvr
Joined Oct 15, 2009
5,394
"higher" amperage protos are typically done with wires soldered to the traces to increase the current carrying capacity like stated above or done without a PCB at all..(ie point to point wiring to terminal blocks,etc..)
8 amps on a real fabricated PCB is nothing.. Done ALL the time. I do 100 amps on PCB traces all the time. Usually double sided traces as wide as I can make them with thermal vias to spread the heat.
x1222
Joined Oct 22, 2011
31
Thanks guys. I think adding extra solder to the traces will be the easiest way. A 20 AWG wire can hold 11 A, so should I aim to add enough solder on the traces to match the volume of the 20 AWG wires?
Ya I guess 8 A isn't exactly high current. What are you making that uses 100 amps? Is it for work or hobby?
wayneh
Joined Sep 9, 2010
17,498
Solder has a bit over 5x the resistance of copper.
That's interesting. It argues for making a solid mechanical connection of two copper wires before applying solder, as opposed to tinning the two ends and just laying them together with solder making the only bond. Stressed to the limit of current, the latter bond ought to overheat and fail like a fuse.
x1222
Joined Oct 22, 2011
31
Didn't think about the extra resistance of solder, but it doesn't seem like soldering copper wire will be worth the extra effort for my circuit. The resistance for 1000 ft of 20 AWG wire is only 10 ohm. I don't think I will use more than 5 ft worth of soldering trail.
DickCappels
Joined Aug 21, 2008
10,187
Dealing with 20 amps on a PC board, I put down about 6 mm wide traces, then soldered some #12 copper wire along it. The combination is just barely enough to keep the trace from falling off the board. Should work a dream in your case.
