What are those slots on the multimeter "EBCE" ?
Discussion in 'General Electronics Chat' started by zero_coke, Nov 15, 2011.
  1. zero_coke
    Thread Starter Active Member
    Apr 22, 2009
    294
    What do they do? Is it to test transistors to see if they match and such?
  2. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    Yes, it's for testing transistors. You can use the slots to figure out whether it's an NPN or PNP transistor, which leads are E, B, C, and what the approximate gain (hFE) is at some fixed current (low current, in the mA range).
  3. MrChips
    Oct 2, 2009
    12,643
    3,457
    It is to test the hFE of a single transistor. They provide 4 connections to the 3 leads on the transistor so that you will be able to match any of all the possible different pinouts of transistors.
    edit: (Almost beat Wookie this time... but not quite.)
  4. zero_coke
    Apr 22, 2009
    294
    Whats the hFE?? And I don't get how to use them...the slots are smaller than the transistors' pins so how would I be able to connect it to test?
    And how would you know if its an NPN or PNP by using it??
  5. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    hFE is "the small signal forward current gain of a bipolar junction transistor".
    It's often abbreviated simply as "gain".
    If your transistors' pins are too large for the slots, then you will need to use some wire jumpers.
    To start off with, you look up a datasheet for the transistor. They usually have the transistor terminal connections documented in some fashion. Then try that combination and see if it works (you get some positive number greater than 5 on the meter display).
    If you can't find a datasheet, then just try every combination of the three terminals, on both the PNP and NPN sides.
  6. bertus
    Administrator
    Apr 5, 2008
    15,806
    2,389
    The following table has the basic parameters for a lot of transistors:
    transistor_tabel.xls.zip
    Just unzip it and load it in excell or OOOcalc.
    Bertus
  7. Audioguru
    Dec 20, 2007
    9,411
    896
    I understand that hfe is "small signal AC current gain" and hFE is DC current gain.
  8. zero_coke
    Apr 22, 2009
    294
    So how can I find out if two transistors are "matched" using my multimeter? And also, which setting do I dial my multimeter to to even test this thing on? The resistance, voltage, or current?
  9. Audioguru
    Dec 20, 2007
    9,411
    896
    Turn the dial on the multimeter to "transistor test" or something similar.
    Plug in a transistor with its pins according to the label on the multimeter (look at the datasheet of the transistor to see which pin is which) and record the hFE number. Then plug in more transistors and do the same.
    When you have two transistors with the same or similar number then their hFE are matched at that tested current.
  10. zero_coke
    Apr 22, 2009
    294
    But there's no writing on my this stupid cheap multimeter I have...which symbol is for "transistor test"? There's a whole bunch of symbols but I'm only familiar with mainstream voltage, current, ohms, and a couple others but that's all.
  11. Audioguru
    Dec 20, 2007
    9,411
    896
    Post a clear photo of the front of your multimeter.
  12. MrChips
    Oct 2, 2009
    12,643
    3,457
    Your meter should have two switch positions marked NPN and PNP.
  13. Adjuster
    Dec 26, 2010
    2,147
    300
    I have seen some meters with a single switch position marked hFE, the meter being provided with separate socket positions for NPN and PNP transistors.
    It seems very strange though if the meter has no markings - perhaps they have worn off, or are in a foreign language (Chinese?).
  14. thatoneguy
    Feb 19, 2009
    6,357
    718
    Meter should have a roatary position for H_{FE}, usually hidden around the diode check/continuity.
    Some meters only have 3 pin sockets, unlabled, and will auto identify (NPN, PNP), show pin out (EBC, CBE, etc), then show gain, giving about 1 second to each display and cycling through them until you remove the transistor.
  15. samin
    Member
    Oct 14, 2011
    32
    6
    It is marked with a hFE sign. Rotate your Multimeter’s pointer and make it point toward hFE sign. Then put the transistor in the according space and you will get the beta value at display.
    Also, the only way the hFE test could be useful is that you check the hFE for each transistor (the parameters of your multimeter are ok) before and after your experimentation, if you get a very different value probably your transistor is fried.
  16. zero_coke
    Apr 22, 2009
    294
    Ok thanks guys! Thank you!
  17. MrChips
    Oct 2, 2009
    12,643
    3,457
    So, which meter do you have? What marking is on the meter?
  18. sheldons
    Oct 26, 2011
    616
    101
  19. zero_coke
    Apr 22, 2009
    294
    Thanks but I already have figured it out. I have an hFe marking on my multimeter but it doesn't seem to work...it just displays 0.00 for any transistor I use anyway so I dunno, maybe its my transistors that are crappy (I'm testing TIP29C, TIP30C, MJE172, and MJE182's).
