What are those cylindrical devices seen on power mains?
Discussion in 'General Electronics Chat' started by lewiso, May 24, 2013.
  1. lewiso
    May 24, 2013
    I gather that they're used to suppress transient spikes? Are they effective on AC? Would they work on a DC circuit?
  2. LDC3
    Apr 27, 2013
    920
    160
    Could you post a picture?
  3. Dodgydave
    Jun 22, 2012
    5,172
    779
    Do you mean Capacitors as used in fluorescent lighting and motors?
  4. kubeek
    Sep 20, 2005
    4,691
    806
  5. PatM
    Dec 31, 2010
    81
    72
  6. DerStrom8
    Feb 20, 2011
    2,428
    1,329
    I think the OP is actually referring to the ferrite "bead" clips that clip over power cords:
    http://en.wikipedia.org/wiki/Ferrite_bead
    The are usually used on the DC side of AC-DC power supplies. So that should answer the OP's question, if that is in fact what he's referring to.
    Matt
  7. wmodavis
    Oct 23, 2010
    737
    150
    I think he is referring to pop cans. If over stressed they go POP!
  8. ErnieM
    Apr 24, 2011
    7,447
    1,628
    Might be the ceramic insulators.
  9. GopherT
    Nov 23, 2012
    6,340
    4,094
    The OP could be asking about these cylinders but he seems to have vanished...
  10. dthx
    Member
    May 2, 2013
    194
    14
    yeah....I think he meant those....on telephone poles....
    transformers right....?...stepping the voltage down....right?
  11. THE_RB
    Feb 11, 2008
    5,435
    1,305
    No, he would hardly be asking about using "pole pigs" in his DC circuit.
    The likely device would be those cylindrical ferrite suppressor beads they use in PC power supplies and appliances for common mode noise/spike suppression.
    DerStrom8 likes this.
  12. atferrari
    Jan 6, 2004
    2,674
    785
    He found a way to create suspense.
    Will he come back?
    Will he tell us what those things are?
  13. GopherT
    Nov 23, 2012
    6,340
    4,094
    Thanks, that was my point. I know he wasn't talking about pole transformers (I hope he wasn't), but we all keep guessing even though he is not coming back.
  14. tubeguy
    Nov 3, 2012
    1,157
    197
    Yep. Those are transformers. We had one near our house explode during a storm. You can imagine...
  15. DerStrom8
    Feb 20, 2011
    2,428
    1,329
    You don't even know what the OP was asking about, how do you know they're transformers? :rolleyes::p
    We still need the OP to post a photo.
  16. YokoTsuno
    Member
    Jan 1, 2013
    41
    9
    I assume you mean these things: http://en.wikipedia.org/wiki/Ferrite_bead
    These are used to increase what is called the common mode impedance of the power cord. This:
    -Attenuates part of the EMI (the one with reference to earth) generated by the device and therefore prevents it from spreading further via the power lines.
    - Reduces the device's sensitivity to external EMI.
    Yes, these things can also be used for DC, In fact they are, since you often see them at the DC side of notebook adapters.
    They often provide an easy work-around for circuits that would not pass EMI standards without spending months of attempts to change circuit lay-out.
  17. DerStrom8
    Feb 20, 2011
    2,428
    1,329
  18. YokoTsuno
    Member
    Jan 1, 2013
    41
    9
    Probably need spectacles :D
  19. DerStrom8
    Feb 20, 2011
    2,428
    1,329
    Yup, same here :p
