What are these components
Discussion in 'General Electronics Chat' started by rustypigeon, Jun 4, 2013.
  1. rustypigeon
    Jul 25, 2010
    21
    I googled the number on them but I can't seem to find any datasheets on them.
  2. Shagas
    May 13, 2013
    802
    74
    They look like resistor nets or whatever they are called . Basically many resistors in a small package probably used for led's or similar stuff .
    Use your multimeter to confirm
  3. Georacer
    Nov 25, 2009
    5,151
    1,266
    I second that. Resistor network.
  4. absf
    Dec 29, 2010
    1,493
    374
    These resistor network can have a few type of wiring. You can refer to the datasheet of the bourns on page 2.
    Allen
  5. MrChips
    Oct 2, 2009
    12,624
    3,451
    I cannot read the markings on the black and red ones.
    The tan colored ones are Bourns resistor networks.
    My guess, as far as I can see:
    10x-1-102
    12x-2-103
    The first numbers give the number of pins.
    10x = 10 pins
    12x = 12 pins
    The second number gives the resistor configuration.
    e.g.
    10x-1 = nine resistors connected to a common pin-1
    12x-2 = six individual resistors
    The last number is the resistance value:
    102 = 1kΩ
    103 = 10kΩ
    http://www.bourns.com/data/global/pdfs/4600x.pdf
    #12 and screen1988 like this.
  6. rustypigeon
    Jul 25, 2010
    21
    Thanks guys!
  7. PDKarber
    Aug 17, 2008
    I know this is an old post but wanted to say thanks for the info. We have a old part for the C17 Simulator program and this allowed us to ref the correct resistor. I knew I joined this group for more than supporting my robot habit...
  8. mcgyvr
    Oct 15, 2009
    4,787
    973
    SIP resistor is the "most correct" term for the components shown above..
    A simple resistance measurement can verify the values when a marking is not sufficient.
  9. THE_RB
    Feb 11, 2008
    5,435
    1,305
    I buy these all the time. You are correct with the markings, apart from one small technicality;
    The -1 or -2 mark in the middle of the number is "how many external pins per resistor".
    So a 8x-2-103 is 8 pin, 2 pins per resistor (ie 4 resistors), and 103 is 10k (10 with 3 zeros).
    An 8x-1-103 has 8pins and 7 resistors.
    And a little known fact; in a pinch you can snap them to length, to give the amount of resistors and pins you need. You need two pairs of pliers to snap in the right place, and a spot of nail varnish to seal the end. Internally they are just a ceramic strip with resistors placed along it.
  10. WBahn
    Mar 31, 2012
    18,085
    4,917
    I did that to some a number of years ago and discovered that the end resistor or two changed noticeably from the stress. I found that using a pair of dikes reduced the problem significantly.
  11. THE_RB
    Feb 11, 2008
    5,435
    1,305
    Dikes? Is that a US term?
    I use two pairs of good quality needle nose or pointy nose pliers, and don't make a habit of snapping them but it can be done in a time of need with no problem. Like in case of needing a fast repair or for easy prototyping, without time delays to order parts.
  12. Metalmann
    Dec 8, 2012
    700
    223
    Some people call sidecutters, dykes/dikes.
  13. THE_RB
    Feb 11, 2008
    5,435
    1,305
    Ahh! Thanks for the clarification. :)
