What are these components?
Discussion in 'General Electronics Chat' started by drkblog, Oct 18, 2012.
  1. drkblog
    Oct 4, 2012
    109
    Hello. Here we go again :) What are these?
    Markings
    1. 07 / K250 / 9538
    2. SCK 2R55A
    3. Gold, Yellow, Green, Brown
    4. 9740J / SFH 617-2 / X001
    5. BY / 206 / F831
    6. Various colors
    7. BZX / 5V6 / 55C
    And: What's a "GLASS PASSIVATED JUNCTION RECTIFIER"?
  2. MrChips
    Oct 2, 2009
    12,624
    3,451
    I am gonna make guesses here:
    1. MOV
    2. MOV
    3. MOV
    4. Bridge rectifier
    5. Diode
    6. Diodes
    7. 5.6V Zener - the only one I am certain of
    drkblog likes this.
  3. Dodgydave
    Jun 22, 2012
    5,143
    768
    1,2,3 are Surge protectors, or Inrush limiters (movs)
    4,bridge diodes
    5,6 diodes
    7, 5.6v zener
    All look like they are from a power supply.
    drkblog likes this.
  4. drkblog
    Oct 4, 2012
    109
    Thank you both!
    I have a bunch of diodes (figure 6) they seem to be silicon (0.6V). But is there any hope of finding out more information?
    5 was a diode, actually, with 528mV tension (silicon I guess).
    Should I keep these MOVs? Is there a chance of using them while designing a circuit?
    Update:
    4 is an optocoupler >> http://www.alldatasheet.com/view.jsp?Searchword=SFH617-2
  5. THE_RB
    Feb 11, 2008
    5,435
    1,305
    3 may be a thermistor. Try measuring it's resistance cold and again after holding a soldering iron NEAR it for a while. If so it might be useful. Otherwise if they are all MOVs probably no use to you at all. :)
  6. bertus
    Administrator
    Apr 5, 2008
    15,799
    2,385
  7. t06afre
    May 11, 2009
    5,939
    1,222
    Most of these components look like they have come from a switch-mode power supply. Number four is certainly not a bridge rectifier. It is a 5.3 kV optocoupler from the SFH617A series quite common in switch-mode power supplies. In picture six. The component with a red band in the middle is most probably an inductor. The rest some kind of diodes I will guess.
  8. larryhfish
    Oct 11, 2012
    There are two styles of passivation for rectifiers. Silicone rubber and glass. Rectifiers can absorb moisture through the plastic package. Glass passivation seals the sides of the junction preventing additional leakage current. Silicone rubber is supposed to do the same job, but it is invariably not so good. Pay any extra cost you have to for the glass passivation or your rectifiers will fail after just a few weeks.
  9. kubeek
    Sep 20, 2005
    4,687
    805
    Why should any modern rectifier in plastic package fail after a few weeks? Not to say an IC in a plastic package?
    What you claim souds fishy to me.
  10. THE_RB
    Feb 11, 2008
    5,435
    1,305
    Sorry but I believe they are all glass diodes. That one with a red band is a common look for a 400mW zener.
  11. drkblog
    Oct 4, 2012
    109
    Thank you guys!
  12. t06afre
    May 11, 2009
    5,939
    1,222
    Might very well be so. At the first glance it looked like an inductor. But i have been proved wrong before in this forum:eek:
