What are these circuits?
Discussion in 'General Electronics Chat' started by David Waddell, Jun 1, 2015.
  1. David Waddell
    Dec 3, 2014
    24
    What type of circuits are these? Photo 02-06-2015 00 41 45.jpg Photo 02-06-2015 00 41 52.jpg
  2. dl324
    Distinguished Member
    Mar 30, 2015
    3,384
    653
    (a) diode is used as a half wave rectifier
    (b) zener diode is used to set trip point of the comparator (open loop OP AMP)
  3. David Waddell
    Dec 3, 2014
    24
    yeah I know what the components do, but i got this work back for corrections and the teacher wanted to know what type of circuit it is?
  4. dl324
    Mar 30, 2015
    3,384
    653
    Do you still have questions?
  5. David Waddell
    Dec 3, 2014
    24
    Im not sure, I was confused by what he wanted. The questions asked to explain the purpose of the component. I explained it and it was right but he wanted me to add what type of circuit it was.
  6. MikeML
    Oct 2, 2009
    5,451
    1,066
    Fig 1 is a DC power supply. I'll let you refine the description further.
    Fig 2 is a battery voltage monitor. I'll let you figure out under what conditions the LED lights.
  7. LDC3
    Apr 27, 2013
    920
    160
    The first one is a half wave rectifier (like dl324 said).
    The LED in the second one will light if the battery can provide more than 6.2 volts. I suppose you can say that it indicates when a battery is sufficiently charged.
  8. David Waddell
    Dec 3, 2014
    24
    Cheers, that all I needed to know. :)
