You noticed that too, huh.There is still a problem as the currents at the node above R42 do not sum to zero.
Polarity shows direction of current. "+" from where to where. Where do resistances cancel each other? We still have 1 mA through R42. The current just comes from the input of the op amp on the right.All ammeters shows +1mA ??
From post #14 ...Yes, this means that all the current is provided via second op amp.
Fascinating!Re post 14: the physical 200 ohm resistor goes from the left amp output to ground.
The gyrated negative 200 ohm resistor goes from the left amp output to ground.
Thus they are in parallel.
As Dick showed they form a singularity of infinite resistance.
One resistor consumes current to ground. The other sources current from ground. Thus the left amp neither sources nor sinks current from output to load; a small current does flow thru the bias network but not to the external components.
I've been trying for years to develop a good speed controller for a router that I own that works with 110VAC. I've tried phase control using triacs, while monitoring its RPM with a hall sensor, and using an MCU to adjust the phase accordingly, and the result was less than mediocre for my taste. I then tried using a high power mosfet with the same MCU-sensor technique, and while the result was a smoother one, its response time was still too slow.Now I power the drill from a power supply with a negative output resistance that partially cancels the resistance in the armature and lead wires so that now the drill maintains nearly constant speed under load and operates much more smoothly than before
1. Perhaps.Do you think that using a negative output resistance power supply would deliver better performance? How hard would it be to design one for this purpose?
How much power is used to create a little negative resistance? We use 5 mA, maybe 10, to counter 1 mA in negative resistance?1. Perhaps.
2. Based on your experience I would say "very hard." your looking at designing an AC source for an unknown motor type, not that I am any expert on motors.
No everything is correct for the gain of 2 input buffer.??? Did I do something wrong
