What am I overlooking?
Discussion in 'Homework Help' started by DYLH, Oct 8, 2013.
  1. DYLH
    Aug 13, 2013
    28
    Please see the link: https://www.circuitlab.com/circuit/36b4ct/circuit-3-29/ or attached .png
    The loop at the top w/ the 2A current source... assuming the voltage meter VM2 is 'perfect' and draws no current, how can the current through R8 be anything other than 2A? Intuitively, I was expecting the voltage at VM2 to be 667mV.
    FWIW, originally the 'top' loop was flipped, and inside the larger loop... I thought I was clever for 'flipping' it outside to clearly see that the current through the loop couldn't be affected by other loops (e.g., using mesh analysis).
    etharijha likes this.
  2. bertus
    Administrator
    Apr 5, 2008
    15,809
    2,390
    The top line and bottom line both have a grounding mark on them.
    This will tell you they are connected.
    Bertus
    DYLH likes this.
  3. shteii01
    Feb 19, 2010
    3,519
    515
    Additional current enters the R8 branch.
    If the R8 and 2 A current source were forming a loop, without any other connections, then yes, the current in the loop would have been 2 A. However, your R8+2 A current source loop is connected to another loop, that is where extra current comes from, looking at the ammeter in series with R8, the external loop provides 0.123 A.
  4. DYLH
    Aug 13, 2013
    28
    Hi Bertus - Yep, overlooked that! Was able to work it out.
    Small world, I'm actually taking a trip to Amsterdam this weekend to see Van Gogh and Ann Frank.
    Thanks again!
  5. MrChips
    Oct 2, 2009
    12,657
    3,461
    Next time please use a title that is more descriptive of the problem.
