What am I not seeing / Help troubleshooting
Discussion in 'The Projects Forum' started by nerdegutta, Aug 8, 2010.
  1. nerdegutta
    Thread Starter Moderator
    Dec 15, 2009
    2,572
    807
    Think I'm going blind.
    Goal: make a 555-based buzzer, with piezo/8 Ohm speaker.
    Schematics, see attachment, I'm trying to build the one on the right hand side.
    When I assemble the parts on a breadboard, it sounds perfect, even with a 8Ohm speaker.
    But: When I draw the schematic i KiCad, and make a PCB, it's only coming some strange "hizzzzz" noise. Not what I would expect.
    I've nearly spent all Sunday, on this little simple task. :(
    What is the different between my schematic and the one on the right hand side?
    I'm open for any ideas and suggestions.
  2. Wendy
    Mar 24, 2008
    20,772
    2,540
    Care to show us both sides of the PCB board in a common graphic format?
  3. mik3
    Feb 4, 2008
    4,846
    63
    Have you checked if the PCB is fine (tracks, shorts etc)?
  4. nerdegutta
    Dec 15, 2009
    2,572
    807
    Here are some pictures, component side and copper side.
    I guess I've stared too much at them...
    I appreciate tips on placing components for more efficiency.
  5. tracecom
    Apr 16, 2010
    3,880
    1,396
    In your schematic, C2 is connected to the wrong side of R3. C2 should be connected directly to pins 6 and 2 of the 555. You have it connected directly to pin 7.
  6. Wendy
    Mar 24, 2008
    20,772
    2,540
    Yep, that is what I'm seeing.
  7. nerdegutta
    Dec 15, 2009
    2,572
    807
    You are absolutely right. When I 'quick' soldered the capacitor to the copper side, it's working.
    Thanks a lot!
  8. Wendy
    Mar 24, 2008
    20,772
    2,540
    I hate that when it happens, but it happens to the best of us.
  9. nerdegutta
    Dec 15, 2009
    2,572
    807
    It's good too hear that I'm not the only one, staring and staring at a simple circuit. Without seeing the solution.
    Thanks again for the help.
