What am I doing wrong?
Discussion in 'The Projects Forum' started by jean28, Oct 21, 2012.
  1. jean28
    Sep 5, 2012
    76
    I have built the following circuit:
    http://i1226.photobucket.com/albums/ee410/jean28x/pspicemodel.jpg
    However, when I try to simulate it, I get an error that says "Simulation aborted because there are errors during netlisting. Please refer to the sessions log."
    What am I doing wrong? I'm new with PSPice so i'm not sure what's wrong.
    Thanks.
  2. Ron H
    Apr 14, 2005
    7,050
    657
    You have no power supply, and the op amp output is shorted to the positive power supply pin.
    When you get these two items fixed, note that, since the input is referenced to zero volts, you will need positive and negative power supplies.
  3. jean28
    Sep 5, 2012
    76
    Okay...could you help me with this? Which power supply should I put and where?
  4. Ron H
    Apr 14, 2005
    7,050
    657
    Do it like this (see attachment).
    Be aware that I don't have Pspice. if you want simulation help here, most members use LTspice.
  5. jean28
    Sep 5, 2012
    76
    I still get the same error even after the modifications, but thanks a lot for trying to help.
  6. Ron H
    Apr 14, 2005
    7,050
    657
    What does the sessions log say?
    Also, post your new schematic. You may still have errors.
  7. jean28
    Sep 5, 2012
    76
    This is the error I get:
  8. Ron H
    Apr 14, 2005
    7,050
    657
    OK, start by fixing these errors, then come back with results and questions.
  9. atferrari
    Jan 6, 2004
    2,672
    785
    Why not to start afresh and see what comes out?
    It will take less than 5 minutes.
  10. jean28
    Sep 5, 2012
    76
    I started fresh, fixed a few things, and then got this new error:
    http://i1226.photobucket.com/albums/ee410/jean28x/pspicerenewed.jpg
  11. Ron H
    Apr 14, 2005
    7,050
    657
    Is V1 a VAC or VSRC source? The syntax for an AC sweep is different or each type. See Chapter 10 in the User Guide.
    I would advise you not to try the noise analysis until AFTER you get the AC analysis running. Debug one error at a time.
